11-14-2013 05:33 AM
Hello Experts,
I would like to seek your advice on the best way to go about this problem.
I have a stream of acquired voltage data that is going into an array. When I press the Start button, a test will start and the voltage will increase. After the test period, the voltage will reduce back to it's original value.
Question is, I would like to analyze the data by having the average value of the votlage during the test period and when it is outside the test period. How do I do this using the data in that array ???
Example of what I want:
Test Off .... Test On.... Test Off
V1 V2, V3 V4
Average Test Off voltage = (v1+v4)/2
Average Test On voltage = (v2+v3)/2
11-14-2013 05:54 AM
11-14-2013 06:09 AM
Hello Jim,
Could you please provide me your VI ? Thank you.
Also, I just realize that perhaps Array Subset would be a way to go.
11-14-2013 06:27 AM
11-14-2013 06:54 PM
Hello Jim,
Thank you for your recommendation of using Delete from Array. It's useful.
However, in the end, what I did was that I put a case structure to store the data in two set of arrays for when the test is ON and when the test if OFF.
Cheers
