02-11-2009 09:06 AM
I inherited some RT code that makes liberal use of the Build Array function--even in time critical loops--which I know is a no-no. I am looking into ways in which I can remove those jitter-inducing function calls while still maintaining the original design pattern. What I would like to do is preallocate the arrays to the maximum size and then replace subsets of the arrays as needed. The problem is, I need to read from the arrays periodically, and I need to be able to step through the elements using an auto-indexing For loop, so I don't want dummy data causing unnecessary iterations/calculations.
My initial idea was to preallocate an array to the maximum size I would need, then immediately delete the contents and begin rebuilding it using the Replace Array Subset function. However, if that even works (to be honest, I haven't even tried it yet), I figure the most that will buy me is some contiguous memory space to work with (to avoid fragmentation), but I imagine I will still be invoking the memory manager, and thus still introducing jitter each time I add data back into the array. Can anyone comment on that? Am I right? Or horribly, horribly wrong?
I also thought about trying to use the new Lossy Queue available in 8.6 to create a circular buffer, but that doesn't help me with utilizing the auto-indexing feature of For loops, since I would still have some dummy data in it.
Can anyone offer any suggestions as to another way I might handle this situation?
02-11-2009 09:12 AM
Do the pre-allocate and then use replace array sub-set so the buffers stays at fixed size. Don't clear the buffer because that will put the buffer back in the pool for use elsewhere.
Still use your for loop but wire the iteratin terminal with the actual count of valid elements in your array while still using the indexing terminal to step through the array.
Ben
02-11-2009 09:13 AM
02-11-2009 09:13 AM
02-11-2009 09:24 AM
LV_Pro wrote:
Ben types faster than I do!
"We don't need no stinking spell checker"
Ben
PS you may also want to review these tags and the related tags where I have collected a bunch of threads that talk about performance.
02-11-2009 10:10 AM
11-23-2013 07:33 AM
Reviving this old thread. I need some tribal knowledge.
I have a cRIO system, developed in LV2011 that is crashing - apparently running out of memory. Using the VI analyzer tool kit on similar VIs in a LV2013 project, I discovered some bad practices that I must blame myself for. Chief culprit right now is the 'Arrays and Strings in Loops' error. According to the result window, the analyzer does not check for this condition within timed loops, of which I have plenty.
I am currently running the vi profiler to hopefully get quantification before and after I fix the remaining build arrays within while loop issues that I have - the above snippet shows 30 cases alone (each case is pretty much identical excepting the variables being 'packed').
So, in fixing the others that the analyzer found I ended up using a Bundle and then a cluster to array. (This example is not Booleans being packed into a word but presented to show how I eliminated at least one of the 'Array and String in Loops' error from the vi analyzer tool kit).
The input array is pre-allocated outside of the while loop. And I only have this situation packing the Booleans outbound in the Modbus array(s). Packing the words, I use no build array function, rather the replace array subset.
Questions
1) Is this a valid way to replace the build array?
2) What would be better?
3) On my LV2011 machine I do not see an option for running the VI Analyzer, was it available then? Or did I simply not install it.
11-23-2013 08:34 AM
Why not expand the Replace array and wire all booleans directly? The Cluster to Array must be way worse than the other option.
/Y
11-23-2013 09:33 AM
The array is U16. How would I wire booleans to it?
"The base data type of the new element or subarray must be the same type as the input array."
11-23-2013 09:39 AM - edited 11-23-2013 09:41 AM
Insert a bool to 0,1 in between 🙂
(This also adds to the suggestion of booleans coercing to 0,1 if connected to numeric functions)
You could also optimize by using the build array and bool array to number, in which case they'll be bits/flags in a single U16. (requires some redesign though)
/Y
