Arduino not showing expected value in Labview
I have a Arduino UNO board. Also Arduino firmware(1.0.1).
I want to use Accelerometer MMA 7361 and the code for that is as follows
 ************************* attached CODE.txt file***********************************************
This code gives values of X Y and Z axes as shown in Image A (attachment)
Also i have made a code in Labview to Read three Axes data using three parameters in Arduino functions Intialize ,read Analog Port and close Ref.
But it is reading values which are more complex than the real ones.
I have make some changes in Read analog Port VI of arduino (attached in Image 3). And removed the part which is not showing the result (I don't understand why).
 Also i have attached VI for arduino Read port.
-Mangesh
Message 1 of 1
(2,437 Views)
