04-16-2014 06:52 AM
i want to connect an Arduino Uno Developer Board to a NI sbRio 911 FPGA board. The Arduino will be connected to the Seriell Port J1 on the sbRio.
My Problem is, how can I use the seriell Port on sbRio in LABVIEW? I can´t find the right Port for the communication. Can someone please help me?
04-23-2014 02:57 AM
HI,
look into this tutorial:
http://www.ni.com/white-paper/9595/en/
hope that helps...
Anna
04-23-2014 08:19 AM
Thanks for your help 🙂
One question I have, what is the name of the port J1 in the Labview software?
In the example usually is something like Port8/DIO0, what is this name for the serial port J1?
04-23-2014 08:41 AM
I'm not sure. I think you can add every possible FPGA I/O to your project. Hopefully the name is J1 🙂
04-23-2014 10:26 AM
But I don´t want to connect FPGA I/O. I want to use the serial Port for communication to an Arduino Uno with the RS232 Protocol....And therefor I have to now how the Port J1 is called in Labview Software....so thats the big question
04-24-2014 02:11 AM
HI,
did you look into this?
http://forums.ni.com/t5/LabVIEW/sbRIO-9631-and-communicating-using-RS-232/td-p/1405868
You have to have installed the NI-VISA and NI-Serial RT on your sbRIO.
then you can communicate over the COM-Port.
Which sbRIO do you have? I think there was a typing mistake in the subject.
Anna
04-24-2014 04:25 AM
my Rio is SbRio9642....
Thank You so far, I hope I will take it now
