Aquire two analog inputs & How to put in array
Hi Nitin,
Main concern is the single  counter value is printed ten times .... How to make it one time .
You need to change the condition for your case structure: right now you write the value when the signal is over the threshold limit. You only want to write when the signal is the first time over the limit so you need to detect a rising edge here!
Did I mention RisingEdge detection before?
Message 31 of 41
(780 Views)
Hi Mr gerd
Greeting to you
I need a support .
I am using report generation  fro excel . Whenever i am pushing data into excel using append to file it get into row .
I want to put in Coloumn.
Please help dear .
Warm regards
Nitin
Message 32 of 41
(709 Views)
Hi Nitin,
I don't use RGT, so cannot comment on the behaviour of this very toolkit.
What I can comment is: when using Excel you can always provide a Cell location where the data is written to. You just need to suplly that cell "range"…
Message 33 of 41
(705 Views)
Hi Gerd
I need a support
Please take  refernce of attahced image.
For saving data i am using 3 different excel . can i do it in a one?
Please tell the solution .
Thanks & regards
nitin
Smiley Happy
Message 34 of 41
(692 Views)
Hi Nitin,
yes, you can.
Build your 6 1D arrays into a single 2D array! (It might take a liitle more effort when your 1D arrays have different length…)
Message 35 of 41
(676 Views)
Hi Gerd
Thank you for youre quick response. I am delighted to see your support .
instead of doing with single array , i did with the logic as shown in pic.
I am facing a problem that only one/ two blocks data are captured in exel. not all.
Please review it .
Thanks & warm regards
nitin
Message 36 of 41
(662 Views)
Hi nitin,
your TRUE case to save save the "whole" data set is called when atleast one of your "single" case structures is TRUE.
As you don't show what's inside the FALSE case of all your case structures I guess you simply output empty arrays in that case.
Solution: Don't do this!
Message 37 of 41
(645 Views)
Hi Gerd
Fine.
how to implement ? through single dimensional array ?
if yes then i don't know how to deal in this case .
Message 38 of 41
(637 Views)
Hi Nitin,
use shift registers in the main while loop. Don't use them (or those feedback nodes) inside the case structures!
Then it becomes quite clear how to wire all your data…
Message 39 of 41
(633 Views)
Hello Mr gerd
Greetings to you !
i need a support .
I am having torque sensor whose output is analog voltage.
at idle condition it will give some micro volts  and the same can be seen on Vi also if we take this input to data aquisition card.
I want to do a logic say "when i start running the VI and after that if a button is there say b1 and i clicked it  then it should make the value coming as zero(arbitrarily value coming in milli volts ) bascially saying level shifting  ie  making it as zero then i will start the  torque sensor to get the data  ".
Thanks & regards
Nitin
Message 40 of 41
(614 Views)
