09-26-2014 02:10 AM
Hi
I don't know how to use spreadsheet , Can you please give me a Example .
Regards
nitin
09-26-2014 02:17 AM
09-26-2014 05:08 AM
Hi Gerd
I tried But nothing is coming in Spreadsheet . Infact .Xls file is geeting damaged also .
please have a look at attahced VI snapshot .
regards
nitin
09-26-2014 05:14 AM
Hi Nitin,
there has to be atleast one value in the spreadsheet file…
- Do you know the difference between spreadsheet files and XLS files? LabVIEW writes simple text files containing CSV data. Please keep this in mind!
- When you want to save more than just the value of the last iteration before stopping your loop you might think about putting the save operation into the loop…
09-26-2014 05:22 AM
Thanks Gerd
I will Ping you Once again .
You are a nice person .
09-29-2014 02:18 AM
Hello Gerd
Sorry to disturb you again ?
I have a querry & its regarding Vi snapshot i shared previousley .
You give me a logic for the counter , is there any block or some function that will do the task mentioned in Green " counter is countinousely counting for the first analog signal but whenever the slow analog input change from low to high counter value is captured .How can i capture caounter value when condition is satisfied ".
Thanks & Regards
Nitin
09-29-2014 02:27 AM - edited 09-29-2014 02:28 AM
Hi Nitin,
using light green on light grey backgroudn is kind of hard to read. Use a different color next time… 😉
You need to use the second AI as condition for your counter. Detect rising edges on this signal and whenever you have found one you read the current value of the counter.
It's a simple IF-THEN condition, quite easy to implement with a case structure…
09-29-2014 05:18 AM
Hi Gerd
I tried , Please have a look at the Vi only the final value is written in file instead of the value at trigger point . .
Is it possible to send these values to excel instead of notepad ?
Thanks & regards
Nitin
09-29-2014 05:35 AM
Hi Nitin,
You need to program this! Write data to your file when the "trigger point" is reached!
You already write a spreadsheet file so you can easily load the data with Excel. I don't see any call for notepad in your picture…
Why do you count both signals? You said you want to use one signal as a gate for the other one!?
09-29-2014 05:51 AM
Hi Gerd
I want to count other signal pulse also , so that's why i used two sepertae counters .
Anyways but i am still confused how to write into file when trigger point is reached for this i created the case structure also . It is visible in VI .
For Notepad call , I am doing it in front panel . and i tried to open it in excel . Its working ...
Main concern is the single counter value is printed ten times .... How to make it one time .
