Application Crashes when writing to TDMS
My application written with LabVIEW 2009 (9.0.1) crashes occasionally when writing to a tdms file.  The application logs data to a tdms file at low sample rates (~1/min).  Attached is the error information.
Could my error be related to this thread.
Storage VI error thread
Mark Yeager
(2,526 Views)
Here is the tdms write code.
Mark Yeager
(2,492 Views)
Could you post the other part of your code?  This could help in trying to determine what is causing the crash.  Also the images that you posted are very hard to see.  Could you post a better image?  How often does this crash occur?
Brandon Treece
(2,472 Views)
Brandon,
I attached better pictures.
This crash seems to occur randomly.  However, It usually occurs after a day or two.  I can't send the exact code, but can send the a simplified version of the code.
Mark
Mark Yeager
(2,455 Views)
If you could post the simplified version that would be helpful.  I am not really sure what is going on here as I have limited information.  You posted the error for CTL Creep DAQ Beta.  Is this your application?  If you could give some more information that would be helpful.
Brandon Treece
(2,418 Views)
