11-24-2016 08:01 PM - edited 11-24-2016 08:02 PM
Hi all,
I like to know if I upgrade me LabVIEW Full to 2016 version, will I still be able to build exe with my Application Builder bought in 2011?
11-24-2016 08:39 PM - edited 11-24-2016 08:40 PM
Good question! I believe that your app builder for LV 2011 will stay intact. I'd check with NI just to make sure though.
11-24-2016 09:06 PM - edited 11-24-2016 09:08 PM
You need the 2016 application builder if you want to use it with LabVIEW 2016.
In order to keep using the 2011 application builder, you also need to keep LabVIEW 2011 installed.
I am sure NI will give you an upgrade path for both. Maybe you can upgrade to LabVIEW 2016 pro, which includes the application builder. Contact your sales rep.
11-27-2016 07:37 PM
Thanks for this. I'll put up a proposal to my management.
