01-15-2015 12:13 PM
Hi, I am very new to Labview and am attemping to take in some analog voltage signals from a PSD (position sensitive detector), do some quick math on the signals to convert to an absolute position, and then create an array/waveform with all the positions that were read while I ran the code and scanned across the PSD. My code works to display the scanning on the XY graph, I just can't figure out how to save all of the positions that are collected during the run... I am trying to add shift registers and 'append waveform' to save all the data, but can't figure out exactly how to initialize/save/display the array that contains the information. Any ideas for a Labview newbie? Attached is a PDF of the bottom of my code that deals with the PSD. Thanks!
01-15-2015 12:23 PM
Hi newbie,
instead of attaching a "PDF" (which is infact a PNG image) you should attach your VI…
- Don't misuse the DDT to apply some "quick math"!
- When you have an array of waveform you need to use IndexArray to index the single waveforms!
- Why do you display scalar "pin"/"coordinate" values from waveforms containing several samples?
- You already discovered the AppendWaveform function, so what's the problem with it?
01-15-2015 02:18 PM - edited 01-15-2015 02:18 PM
Sorry about the PNG, my computer is acting up a little bit and it doesn't want to upload the VI for some reason...
- What do you mean by misuse the dynamic data?
- Would it actually be okay to use append array, as opposed to append waveform? And would I still need to index array?
- I display the 'pin/coordinate' values so I can monitor their values visually while the code runs. What do you mean by several samples? Doesn't it just display the current values for the given sample?
- As for the AppendWaveform function, I am not sure where it is writing to (or how to write to something) so that I can analyze the data from it in another environment (such as Matlab).
Thanks for all the help!
-J
01-15-2015 02:51 PM
