Is there a way to append a report to another existing one. I mean, I have already saved and closed a report as a HTML and I want open and add more data and figures to it. I'm using LavVIEW 8.0.
Any help would be appreciated.
Mike
Message Edited by q123456789 on 02-10-200701:18 AM
I used this vi before, but it deals with the existing report as text. So, the final report I got, (the existing and added repot) is unformated. Could you please explain more.
Hello Mike, I could not find a VI that would open an existing HTML report. Without an "Open Report" VI, you cannot get a reference to your pre-existing HTML report. I recommend opening both html files as text files, concatenating those strings and then replacing the pre-existing HTML file with the combined string. I tested it with just adding some line breaks at it seemed to work fine. Let us know how it works for you.
