08-06-2009 10:11 AM
I have a VI that controls a stepper motor attached to a camera. I want people to be able to access this camera and control its position through the web. Is there any way to append an HTML file or icon from labview and rotate the camera with the data sent from the web?
Thank you for your help.
Guillermo Naranjo
Solved! Go to Solution.
08-06-2009 10:25 AM
08-07-2009 09:19 AM
I tried using the labview web publishing tool like you suggested, but when I tried to preview the page (even with the VI running) I only get the border of the front panel without the VI in it. Do you know why this is happening?
Guillermo Naranjo
08-07-2009 09:27 AM
08-07-2009 09:43 AM
08-07-2009 10:34 AM
08-07-2009 10:45 AM
Thank you very much, I was able to connect to the server.
Guillermo Naranjo
