04-02-2014 06:04 AM
Hello folk,
I need to write 19200000 data into binary file. This data is stored into TDMS file. The file is of 32 channels with 600000 samples for each channel. Now I need to write binary file with 32 columns and 600000 rows.
Doing this with two dimension array lead me to memory full error. Hence I need to write each channel data as soon as I read without building an array.
Please suggest me how to append this channel data into binary file.
Your help will be truly appreciated.
Thank you
04-02-2014 06:15 AM
04-02-2014 06:30 AM
@GerdW wrote:
Hi Jatin,
do you want to store the data in a TDMS file or in a binary file?
When it comes to problem in using 2D arrays then why don't you save your channels as 1D arrays?
Mind to show a VI to explain the problem?
I write data into TDMS file in my RT code. Now I need to convert this file into binaray file. My channels are saved in 1D array format. Since I have 32 channels and for better observation I want to convert .tdms file to binary file with every column having 600000 data.
First I made a code with 2D array format. It works fine but for lesser samples. With raised requirement I need to go with 1D array.
I have attached a code with 2D array format.
04-02-2014 06:52 AM
Hello GredW,
Thanks for your concern.
Here is my upgraded code too with 1D array format. But it writes data into 1 column only.
