08-22-2013 07:49 AM
I was writing a small Host VI to test certain FPGA problems we've been having in the last time.
Test was working fine, and I was refining things step by step. Then I started getting errors "If using external clocks blah blah blah" and was getting errors writing controls in the FPGA code but reading the indicators was working fine. I tried restarting LV, restarting the hardware and nothing was able to remedy the problem.
I finally switched Bitfile (in my "Open FPGA Reference" node) and suddenly the problems went away. I changed BACK again and things worked fine.
This is a very worrying behaviour. I have both VI and Bitfile on a shared network path and the source for the host VI is NOT set to seperate compiled code. During testing, every 8-12 times I re-run the VI after making trivial changes the Bitfile fails to work as expected.
Seeing how we're trying to nail down errors which are occurring approximately 1% of system restarts, this is a VERY worrying sign. Anybody got any experience with this? I'm using LV 2012 SP1 on WinXP running in a Virtualbox VM which in turn runs on a Win7 64-bit machine. My XP machine has the 3GB switch with USERVA set to 2900.
Shane
08-22-2013 07:53 AM
Clarification:
1) Saving the VI (Recompiling) seems to have an X% chance of corrupting the bitfile.
2) Loading the bitfile to the FPGA target repeatedly without recompiling (re-running the VI) seems to work fine over large numbers of iterations
Shane
08-26-2013 03:38 AM
Hi Intaris,
probably the failure occurs due running the application on a virtual machine. Problem is that the VM provides a virtual CPU that may cause timing problems.
Best Regards,
Lars
08-26-2013 07:04 AM
Is there any more informaiton on this topic. Such side-effects of running in a virtual PC are unknown to me.
I don't see how the timing problem could occur in this way, but I'm eager to learn.
Shane.
09-03-2013 04:38 AM
Any more information on this? Is this a real problem? If so then I need to know that my VM is causing the problems.......
09-03-2013 07:35 AM
Hi Shane,
more information about the issue could be helpful.
What hardware do you use?
Are you able to post your example project?
Screenshots of failure messages could be helpful.
Lars
09-03-2013 07:37 AM
As soon as I see the problem again I'll send a copy of the corrupted VI so that it can be analysed to see what's wrong. I'll also send a copy of a non.corrupted VI as comparison. How about that?
It doesn't happen VERY often, but as soon as it happens again I'll make sure to post.
Shane.
