NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
Klaus Hoelscher
Aplication Builder
Hi there,
hope someone can point me to the proper direction.
I am about to create a setup project where the file "serpdrv" (w/o
extension) is included. Everything works fine, besides the fact that
"serpdrv" will not be in the destination directory after executing
setup.exe and thus, when starting the application, an error message is
created saying that a device is "not found", probably because the driver
"serpdrv" is missing. When copying this file manually to the destination
directory everything works fine again.
Are there any particular issues I have to consider when including
"serpdrv" with the setup process, so it will be installed automatically?
Tanks in advance.
Klaus Hölscher
Member
Jared 323
Re: Aplication Builder
Klaus,
From the "Build Application or Shared Library" screen, select the "Source
Files" tab. Then Select the "Custom Destinations" button. Then select the
file in the file list box (serpdrv in this case) and
choose "Install Directory" for the installation directory. Remove any path
in "relative path" box. This should do it.
Jared
"Klaus Hoelscher" wrote:
>Hi there,>hope someone can point me to the proper direction.>I am about
to create a setup project where the file "serpdrv" (w/o>extension) is included.
Everything works fine, besides the fact that>"serpdrv" will not be in the
destination directory after executing>setup.exe and thus, when starting the
application, an error message is>created saying that a device is "not found",
probably
because the driver>"serpdrv" is missing. When copying this file
manually to the destination>directory everything works fine again.>>Are there
any particular issues I have to consider when including>"serpdrv" with the
setup process, so it will be installed automatically?>>Tanks in advance.>>Klaus
Hölscher>>>
Member
Klaus Hoelscher
That was great. Everything is perfect now. Thanks alot, Jared.
Klaus Hoelscher
Jared O'Mara schrieb in im Newsbeitrag:
3a6d8ac9@newsgroups.ni.com...
> Klaus,
"Source
select the
path
> Jared
about
included.
the
starting the
found",
> probably because the driver>"serpdrv" is missing. When copying this
file
again.>>Are there
the
advance.>>Klaus
> Hölscher>>>
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
