06-30-2008 01:01 PM
07-01-2008 01:11 AM
07-01-2008 08:49 AM
07-01-2008 01:31 PM
It it very possible that you have developed your application (.exe) with one version of the NI-DAQ driver on the 98 machine and have loaded a different version of NI-DAQ on to the XP machine. This would explain both error 21 and 10243. There are only a couple of versions of the NI-DAQ driver that support both 98 and XP. Thus, it is very likely that you could have developed on the 98 machine with a version of NI-DAQ that does not support XP. Please check that you are developing on 98 with either of these versions of NI-DAQ 6.9.0, 6.9.3 with patch 6.9.3f5, 7.0, or 7.1. I would recommend using 7.1, since it is the most recent of the Traditional NI-DAQ drivers that support both OS. If you find that your .exe was developed with a version older than 6.9.0 you might need to upgrade the driver on the developement machine.
For error 21, please refer to the KnowledgeBase linked below for more detail.
KB 0ZTKCAWV: Error 21 While Loading LabVIEW Executable on Target Machine
For error 10243, it is looking for a the configuration that it can not open or acces. Please also refer to the linked KnowledgeBase.
KB 3ADBL74B: LabVIEW Error 10243
KB 18K8B88U: All my LabVIEW DAQ VIs return error -10243
Please also make sure that you are using the same version of LabVIEW and DAQ driver on both the developement and target machine.
