An error occured-The NI System Web Server is not running
When ever I try and open an example program I get this error.  Tried re-booting .  That didn't work.  Someting is different because example vis worked in the past.
Message 1 of 22
(18,483 Views)
Accepted by topic author MarkDavid
Hello Mark.
Did you try to repair on of the NI Software you have? There is a known issue where repairing a software unregestier it from the Web Server and makes this error pop up. A solution is to repair the software again to register it anew. Here is the related Knowledge Base article:
Repairing NI Software Installs Leaves NI System Web Server Unregistered
http://digital.ni.com/public.nsf/allkb/2AF18FBF04D29104862578D8004E4A6B?OpenDocument
I hope this helped
Regards
______________
Florian Abry
Inside Sales Engineer, NI Germany
Message 2 of 22
(17,969 Views)
WOW !!  NI Germany??
Thanks..I'll give that a shot.  The only thing that bothers me is I didn't do a repair prior to this hapening.
Message 3 of 22
(17,963 Views)
Yes, There is also NI in Germany Smiley Wink
 Its just I was browsing the forum and had a similar case where this helped, so I though it costs nothing to share the link with you. Smiley Happy
Regards
______________
Florian Abry
Message 4 of 22
(17,961 Views)
Thanks !!!!  That worked.  I would have never thought of that.
Message 5 of 22
(17,950 Views)
I'm stuck with this same issue. Like the previous poster, I didn't knowingly repair my installation, but I did apply the patch for AMD FX bulldozer CPUs ( http://digital.ni.com/public.nsf/allkb/4734A6405B123FA58625799900813593 )... After that, labview will start, but when I try to open any example VIs, it gives me the "An error occured-The NI System Web Server is not running" message. I've gone through and repaired again, but then I need to re-apply the FX patch and I"m back to the error.
Part of my problem is that I didn't knowingly repair any of my distributions, so I don't know which one I need to run the repair on. Do I need to run it on all of them? I've just been running it on the main LV 2011 distribution.
thanks for any help.
mike
Message 6 of 22
(17,574 Views)
Mike,
I'm no expert but you might want to start a new thread.  I don't know how these get assigned to the AEs.  If its marked as solved they may never see it.  Hope you resolve your issue.  They've been great for me.
Message 7 of 22
(17,570 Views)
Thanks. I finally got it sussed. I'll post it here to save someone else some frustration. After the repair operation completes, it prompts for a reboot. Instead of rebooting, I told it "NO", then installed the FX chip patch, then rebooted. That seemed to do the trick.
Message 8 of 22
(17,567 Views)
MarkDavid,
We still see it, but yeah, a new thread doesn't hurt. 🙂
Ravi A.
National Instruments | Applications Engineer
Message 9 of 22
(17,557 Views)
this worked.
Howard
Message 10 of 22
(16,077 Views)
