Allow specific characters - Regular Expression
Hello everyone
I am new to regular expression and I have a very simple question. I use the "read from text file" function to load a Tab delimited file with 3 columns into my VI. Next, the string is converted in array and I use the values.
Nevertheless, I want to develop a "filter" allowing only digits (0-9), colon, comma and point into strings.
Using the "match regular expression" function, I was trying a regular expression like that:
[^0-9]|[^\].[|^:]|[^,]
But it is not working.
Could someone help me with this issue?
Dan07
Message 1 of 11
(3,992 Views)
Accepted by topic author dan07
Use the Search and Replace String function with Regular Expression selected.
Jim
Message 2 of 11
(3,967 Views)
Here's an alternate method using Match Regular Expression, but a wise man once said "When I find myself facing a regex in a loop, I try to see if my old friend Search and Replace can help."
Jim
Message 3 of 11
(3,960 Views)
Hello
Actually I don't need to modify the string that has "invalid" characters, I just need to identify them instead. Find below a VI testing both methods: Match Regular Expression and Search and Replace String.
Using Match Regular Expression method, I got correct results since all the "valid" values must be identified as "-1" and all the "invalid" values must be identified as positive numbers (offset).
Nevertheless, using Search and Replace String method I got wrong results, since all the strings were classified as "valid" (-1), but "bg" and "03/12/2010" are not "valid".
I will go ahead with Match Regular Expression method because it is working great, but I was just wondering how to fix Search and Replace String method to achieve equivalent results.
Dan07
Message 4 of 11
(3,922 Views)
Look closely at Jim's Search and Replace Node then look at yours.  Notice the missing '*' that means that Regular Expressions are not enabled.  Right Click and Select Regular Expression, then try it again.
Message 5 of 11
(3,918 Views)
Darin K.
You are right about that. I changed it to "Regular Expression" and worked great (attached image). It's interesting to see that Match Regular Expression represents the location of the found string starting at index 1, and Search and Replace String starting at index 0.
Dan07
Message 6 of 11
(3,904 Views)
They're both using the same index (starting at zero), but they're looking at different things.  The offset past replacement from the Search and Replace String function is giving the position in the result string.  The offset past match in the Match Regular Expression function is giving the position of the match in the input string.
Jim
Message 7 of 11
(3,833 Views)
jcardmody,
Couple months ago you helped me with a code to check if the string has just valid characters: digits (0-9), coloncomma and point
Why did you use [^0-9:,\.] ?
Is [^0-9:,.] the same thing?
Why did you use the \ ?
Dan07
Message 8 of 11
(3,668 Views)
Escaping the '.' is probably just a habit that Jim has gotten into.  Outside of an alternative '.' will match any character except newline, so it is easy to get confusing results when actually trying to match a '.' unless you remember to either enclose it in an alternative ([.]) or escape it (\.).  Escaping it inside the alternative is unnecessary yet harmless.
Message 9 of 11
(3,656 Views)
Darin
So, the best option for me would be  [^0-9:,][.] ??
Thanks.
Dan07.
Message 10 of 11
(3,651 Views)
