How do you align a waveform with its filtered waveform after you filter it? I need to create an upper and lower limit using a filtered version of a waveform and then use the resulting limits to test it.
thanks but that is what I was using in the attachment I posted and it deosnt seem to work as advertised. Am I doing something wrong in the express VI settings?
What behavior are you observing when you say it does not work as advertised?
Also, the function that Mikhail is different than the one you are using. There is an example listed for this function on your computer in this location labview\examples\measure\resample_align_xmpl.llb
