The latter part won't work because all that you'd be passing is the value of the Boolean, and the subVI would have no way of knowing if that's from a control or a constant. While you
could pass in a control reference of the button and do dynamic event registration, that would be fairly pointless in this situation. Just have the subVI with the file path control and indicator. No event structure in the subVI. Keep the event structure in the main VI. When the user presses the button, call the subVI.
