Agilent E5062A Smith chart
I am reading the output of my network analyser into labview where I want to display and log the same smith chart that is displayed on the analyser.
I am using the input format Smith chart complex (Real & imaginary), then a loop of a 1000 is used to plot each point on the smith chart.
I have tried converting to polar also but this does not work either. The results loop around the open circuit end or are massivley off the scale.
The results on the network analyser spirals around the centre point many times but this is simply due to the large frequency range being measured, this is the result I am trying to acheive.
what am I doing wrong? am I missing out some extra mathematical functions?
Regards
Michael
(3,580 Views)
I would try to change Configure Channel and Trace.vi from Smith Chart Complex (Real/Imag) to Smith Chart Impedance (R + JX).
Ben64
(3,514 Views)
I have tried all Smith chart Format types, none look correct, this is why I was wondering if any extra mathematical functions needed to be applied.
Michael
(3,499 Views)
Accepted by topic author nashm999
I don't know what is your expected result but you can try this (but there must be a better way).
Ben64
(3,487 Views)
This works perfectly for the format Smith Chart Complex (real & Imaginary)
Thank you very much
Michael
(3,466 Views)
What are the resultant units of R and X in given this conversion?
(3,225 Views)
