05-17-2007 04:32 AM
05-21-2007 10:36 AM
05-21-2007 11:12 AM
05-21-2007 11:32 AM
You can create a shortcut on the desktop right to this file and windows will
know how to open it. It is pretty accurate and helpful for describing all
the properties/fields for the functions you can access.
One annoying feature is that while the 89600 displays RF power in dBm, active X
calls to these measurements only report it in VRMS squared. Lovely.
06-01-2007 05:15 AM
I am trying to communicate over a LAN connect to the 89600 VSA software (7.1) based on the Agilent 16903A Logic Analyser. I run the TestConnect.bat provided by agilent to check the DCOM connection and that reports the connection is succesful. I try to run the Labview example program provided by Agilent (see attached) but that just reports back a measurement timeout error after a couple of minutes, and I don't see any effect of the program on the remote screen. The Labview program provided for the Logic Analyser 16903A to run across a LAN connection worked fine. I tried the check version program attached earlier in this thread but that just reported the version on the PC and not the remote 89600.
I have not used COM, activeX until now. If anyone could me a few pointers as to what i should check, it would be much appreciated.
08-28-2007 04:53 PM
It looks like I'm in the same boat as the rest of you. I'm developing a test using the Agilent 89601 software on an MXA spectrum analyzer and am in dire need of drivers. Does anyone have drivers they're willing to share?
Doug
08-28-2007 05:22 PM
09-05-2007 03:16 PM
09-05-2007 03:33 PM
Unfortunately when using the activeX calls, at least with
the graphical interface and VISA, it is very difficult to create a driver
library. Basically you plunk down a visa reference node (ring/menu bar) set to the 89600 app,
then you can create property nodes that let you 'open' a references to sub
functions, or read/write properties. It is difficult to map on screen
functions to these reference openings. You can get these references by using the
macro record option in the 89600. Start with the 89600 in some default mode, then start a record, and setup the insturment to take the measurements. This lets you see what calls are done and how the data is pushed to the settings. You see the call downs you need to do to create a VI that lets you push the same settings. Reading
back data however is very tricky and the macro record trick won't help you decipher
the options and settings of the property nodes for any particular
meter/display.
Here are two particular VI’s that show this issue. The COM help file does
a good job of describing what the read request will provide you with. Remember
that this help file is present on the CD/install directory but the general help
file doesn’t link properly to it. (The file is: com_89601.chm and you can
double click/open it, windows will open the help file reader correctly.)
09-07-2007 07:44 AM
Hi Sparky,
Looks like your upload didn't stick. Any chance you can zip everything up and just attach it to a Reply?
Thanks again,
Doug
