07-16-2014 03:44 PM
Hello all,
I am attempting to get readings off of a thermocouple using an Agilent 34980A unit connected to my laptop via ethernet cable. The VI is based off of an Agilent provided example. It is connected to a T-type thermocouple plugged into channel 9, card 1. I have been able to get numbers and no error codes, however, the output values are basically either infinity or zero.
I have attached screenshots of both windows, as well as the settings of the thermocouple setup in LabVIEW. What can I change to get numbers more in line with reality?
07-16-2014 03:46 PM
@Option13 wrote:
Hello all,
What does the instrument's front panel say? You should be able to see the readings there.
07-16-2014 04:28 PM
07-16-2014 05:24 PM
Yeah, you need to change the example in order to get what you want. There is a thermocoupler setup VI that you need to call instead of the RTD and then get rid of the voltage channel setups.
I hate that Agilent box...give me an NI DAQ card anyday.
07-16-2014 05:46 PM
07-16-2014 05:58 PM
@Dennis_Knutson wrote:
The only thing worse than the 34980 is the 34970.
I now have a new mantra when I have to go to a certain customer's site...
07-17-2014 08:32 AM - edited 07-17-2014 08:34 AM
Oops, guess I uploaded the wrong version! I've been trying to hook it up to both RTDs and thermocouples and have configured the VI with both Thermocouple and RTD Vis. No change. The other VIs are just there for experimentation and to play with, if they present an issue I can remove them.
Here is how it looks now, and has looked in the past on previous attempts. I'll try this again as soon as possible, but can anyone see any issues with the setup?
07-17-2014 09:25 AM
I'm re-factoring an old test that uses the 34970 (just purchased a bunch of 34972A models with USB). They're pricey when you add a few modules but they're very versitile and easy to work with. I would recommend them when you need 6 1/2 digits and lots of input channels. We've only had one unit go down after almost 10 years of constant use.
Any particular reason for the dislike???
07-17-2014 10:11 AM
07-17-2014 10:13 AM
