07-31-2008 03:02 PM
08-01-2008 02:22 AM
Hi holleytx,
maxbe you use different fonts for some of your controls. If you move your code from one pc to another or from development enviroment to runtime, it could be that you have different settings for these fonts. Compare the LabView ini files.
Hope it helps.
Mike
08-01-2008 07:39 AM
I am using 14pt application font for all of the label text. The 2nd and 3rd computers do not have labview installed, just the runtime engine and the executable (installed through the "installer" package that you can create);
On a side note, i have put the executable on a 4th computer, in this case, I just transferred the executable (did not use the "installer") and on that machine, I do not see the label text change colors.
08-01-2008 09:22 AM
One more experiment....
on the 4th PC I removed the executable we used and instead used the installer to reinstall the latest version. All the label text colors are correct!
So currently only PC#2 and PC#3 have this mysterious coloration issue
PC1- XP, LabVIEW 8.5.1, MS Office, Adobe
PC2-Vista, runtime version only, no MS Office/Adobe
PC3-Laptop XP, runtime version only, no MS Office/Adobe
PC4-XP, runtime version only, MS Office, Adobe
08-01-2008 06:49 PM
02-28-2012 03:25 AM
Hi Mike, i too have a similar problem in that my installer makes my tables cell BG colour all black when deployed onto another PC. Can you tell me where i can compare the .ini files?
Best Regards,
Grant
