Adlink products with Labview
i am using a Nudams Network wchich is an ADlink products and i have The labview 6.1 and want to use it with the Nudams so what the additional software component that i have to install with the Labview and where to get it?
thanks in advance
(3,248 Views)
Communication with the hardware will depend on the interface – is it serial or PCI? If it is serial, you can use the low-level serial commands or NI-VISA to communicate with it. If you have LabVIEW 7.0 and above, there is also the Instrument I/O Assistant that will help you get started communicating with the device as well.
If the device is PCI, you’ll probably want to see what kind of driver Adlink provides with the hardware. If they have a dll for the device, you could use the Call Library Function node (within the Advanced subpalette of the functions palette) in LabVIEW to interface with the dll.
Hope this helps. Best of luck!
Kileen
(3,236 Views)
http://www.adlinktech.com/PD/web/PD_List.php?cKind=FN&sid=19&id=3&seq=2
Try this link. They have both Active-x and OPC drivers that you can access from Labview.
Good luck,
Dave
(3,226 Views)
