04-11-2015 07:28 AM
Hi All,
I am Using Adlink USB 2405 card to aquire IEPE sensor data. I am able to acquire data properly with U-test software which is provided by the Adlink. They have privided LabVIEW drivers also but when I use that code to acquire data in IEPE mode signal is being saturated to 30. irrespective of signal in IEPE mode I am able to read only 30.
If any one come across this kind of issue, Please help me in resolving it.
Dev
Solved! Go to Solution.
08-01-2015 10:38 PM
helo,
I have a USB 2405 module as well but I cant install the module drivers in my windows-PC Tablet (Thinkpad 8), running a windows 8.1pro full.
I've already updated the driver from adlinks site but the windows can't recognize the module as driven by the adlink's drive.
Anyone has some clue about how can I possible get things working ??
cheers,
08-01-2015 10:45 PM
01-04-2019 02:25 PM
Know this answer came back 4 years later but will help if someone in the future came across with the same issue. In the library provided by Adlink Named DAQPilot has a PLT Set Channel Property.vi that has 2 arguments (property & value). It will work once you set the property as "IEPE" and the value set it to 107. (ON) or 106 (OFF).
Hope this help someone in the future
Gerar Ballhausen D.
Ballhausen Ingeniería México.
