Addon Files _NISVFA missing
Hi there,
i got a question. I reinstalled a pc and upgraded on Labview 2016 including Sound and Vibration Toolkit 2015.
My old VIs are made with Labview 2012 and Sound and Vibration Toolkit 2012. When i tried to start my old VI there comes a message that he can't find the "svc_Window [Dual FFT].ctl" file.
It should be in vilib under --> addons\_NISVFA\_Shared subVIs\Controls\
I didn't find this folder. I think this should be the files which are included in the Sound and Vibration Toolkit which i already installed. Does anyone have an idea where i get the missing files?
ALso missing are:
SVFA FFT Spectrum
SVFA Frequency Response
SVFA Power Spectrum
SVL Running Leq Sound Level
SVFA Spectrum Peak Search
SVFA Get Spectrum
SVC_Spectrum Info
and a view more...
Thanks for your help!
Maxi
(3,889 Views)
You mentioned that you are using the 2015 version of the sound and vibration toolkit - if you're using LV2016 then I think you need to use the 2016 toolkit.
You should be able to download from the following link: https://www.ni.com/en-us/shop/product/labview-sound-and-vibration-toolkit.html
(blog)
(3,865 Views)
