09-01-2015 06:35 AM
I've went through a few posts here and understood that generally any html function other than Bold will not work in the documentation. Is there another way I can add a link to my documentation in any way?
I've seen this question mark link on the bottom of every vi documentation (on a project I’m working on) but on every vi it takes me to the same address. Is it possible to change this per vi? If possible how do I do it?
This has troubled me for a while now, thanks in advance!
Solved! Go to Solution.
09-01-2015 06:58 AM
In the VI properties under documentation, change the 'help path' to your HTML file. This is per VI setting, so you can set a different file for each VI.
09-01-2015 08:29 AM - edited 09-01-2015 08:53 AM
Easier then I thought, thanks.
Edit: Seems my work would be much faster if I could get the documentation part to recognise the rest of the html functions (because the alternative is to add over 100 html files to my file) Is there a way to do that?
09-04-2015 09:49 AM
Nope, for some reason NI choose to only implement the bold tags in the documentation of a VI. There are several ideas on the idea exchange you can vote for if you want more functionality.
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Text-formatting-in-VI-description-dialog/idi-p/919318
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/VI-documentation-Upgrade/idi-p/1075843
Maybe to help you can set that HTML help information on each VI programatically using VI Server.
http://zone.ni.com/reference/en-XX/help/371361M-01/lvprop/vi_helpdocument_path/
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
