02-25-2014 03:57 AM
Hello guys, i've been searching for a solution to my problem but i can't find the right answer..
Here is the thing ;
I have a variable (let's call it "Variable Case"). Every time this variable goes from 0 to 1, i want to add the value of another variable (let's call this one "Buse défectueuse") to an array of 2D. So far, nothing impressive, but things will get worse now !
To be sure that i correctly added the value of "Buse défectueuse" to my array, i've got another variable (let's call it "Correctly Added") that goes from 0 (nothing happened) to 1(the value has been added to the array). When "Correctly Added" is at "1", i must set the value of "Case" back from 1 to 0 (the variable "Case" is in a while loop that is refreshed every 100 ms so it's very important that "Case" goes to 0 as soon as the writting of "Buse défectueuse" is done) and once "Case" is back to 0, set "Correctly Added" to 0 aswell.
Also, the size of the array is set to 10 elements and each times that a value is written in it, i must increment the value of the index for the next value.
How it should be understood ;
First iteration :
Second iteration :
Third iteration (you got the thing...)
I've got everything working but the "i ++" thingy. Could you take a look at my vi and tell me what i've been doing wrong? Thanks for your help !
Solved! Go to Solution.
02-25-2014 04:36 AM - edited 02-25-2014 04:36 AM
Hi Claude,
in your VI you don't "add" or "insert" data to your array indicator, instead you create a new array (of only one element) each time.
Please go through all free LabVIEW courses to learn LabVIEW basics as autoindexing and shift register usage!
02-25-2014 06:22 AM
If i post something here, that means that i couldn't find the right answer in the courses..
02-25-2014 07:49 AM - edited 02-25-2014 07:53 AM
Hello Claude,
what GerdW meant, is, that you didn't find the answers to a lot of questions.
I modified your VI, so it could meet to some of your needs. Take a look into it and perhaps you can answer the questions that came up to me:
For some reasons, I'm not able to post a VI. I get the error message, that the extension doesn' match the file type.
02-25-2014 07:51 AM
It might also mean the answers were in the courses, but you don't understand what the courses were teaching you.
Do you understand what a shift register is? If you don't, retake the courses. A shift register is what maintains the value in a wire and makes it available at the beginning of the next iteration of a loop.
PS. You don't need the select statement with the True and False constants. Just wire the boolean directly. You have a Rube Goldberg.
