02-20-2014 01:03 PM - edited 02-20-2014 01:04 PM
Something like this? Takes 5 minutes if you understand FOR loops with autoindexing. Please make an attempt at it. Then show us where you are stuck.
02-20-2014 04:07 PM
Thanks for your help.
I have now found a "solution" and have to try it with the rest of my program to see how it goes.
Hopefully Camerond doesn't think that I have left this problem unsolved like my previous question
Regards
02-20-2014 04:10 PM
Regards
Well, at least I know you now realize "how for loops work, with respect to outputs".
Cameron
02-20-2014 04:10 PM - edited 02-20-2014 04:12 PM
Excellent. That looks pretty much like I was describing how to do it.
A few tips.
1. You don't need the wait statements. Since those For Loops run quickly and have a finite number of iterations, you don't need to slow them down.
2. You don't need to wire the value 3 into the N nodes of the For Loops. The number of elements in the array will determine how many times each For Loop runs because of the auto-indexing terminal.
3. You can use the Format into String function to get that string created in a single node without concatenation. %s=%d as your format string, and wire the string and the numeric into the Format into String node
