06-17-2014 01:07 PM - edited 06-17-2014 01:22 PM
Hello again all,
I'm trying to read in in an old XML file to get the data from it and write the data to a new XML file that is nearly identical but has another control for each section. To modify this VI to work I still need to add the "Solder/potting" ENUM (The control that was added to each section) to the array of arrays that is noted .
Basically its just a data flow problem, I'm just trying to get the data types to match. Im trying to add the "Solder/Plotting" ENUM to the Current array of arrays to match the needed output (on the right of the VI) any suggestions?
Thank you all!!
Solved! Go to Solution.
06-17-2014 01:44 PM
My Bad but it's not an array of arrays its a cluster. noob mistake
06-18-2014 09:40 AM
Solved, indexed in with a For-Loop then Unbundled and was able to add normally
