Add comments to a file name
Hi
In my VI when I want to collect and save data to CSV , I use curremt date and time for the file name but I would like to also use a popup message and ask if the operator wants to add a comment to the file name ( just a string ) . Could u plz help me how can I implement it in LabVIEW
thanks
Message 1 of 9
(3,034 Views)
There's an express VI for an input dialog window.  From there, just use Concatinate String to build up your file name and then Build Path to add the file name to the folder path.
GCentral
Message 2 of 9
(3,029 Views)
Unlike Tim I don't really care for the polling that goes on in the Express vi. And, I really hate saving a vi "modal" so I keep a few of these around.Prompt(String).png
"Should be" isn't "Is" -Jay
Message 3 of 9
(3,026 Views)
Heck, I didn't realize the Express VI polled the buttons.  I was just trying to keep it simple for the OP.  I just started hating Express VIs even more.
GCentral
Message 4 of 9
(3,014 Views)
They used to have to since there used to be versions of LabVIEW that did not have events And, I suppose they still have to for backwards compatability.
Message 5 of 9
(3,006 Views)
I call BS.  Express VIs are newer than Event Structures by at least 1 version (Events in 6.0, Express VIs in 7Express).  I think what was missing was the scripting capability to manipulate the event structure and they haven't revisited the express VIs for a while.
GCentral
Message 6 of 9
(2,989 Views)
Not that its that big of a deal but Events weren't in all versions until 2012.  How would a student play with the express vis?  Sure your 6.0 Pro version had events....
Message 7 of 9
(2,980 Views)
Thanks Jeff
I tried to drag the pic into my block diagram but it just copy the URL address toi Block diagram
Message 8 of 9
(2,970 Views)
I jinged it here.  you need to drag to desktop first then drag to BD
Message 9 of 9
(2,968 Views)
