Add Columns of Array
Hi fate,
why do you constantly hijack old threads?
Why don't you create your own thread?
Why do you even send PMs?
Attach your VI with some relevant data in it!
Message 11 of 47
(1,028 Views)
Hi GerdW Knight of the NI
it is BER rate with help of hamming code.
Thank You for your help.
Message 12 of 47
(1,019 Views)
fate,
Try this
Message 13 of 47
(1,015 Views)
You don't have the same function in your VI that you have in your picture.
The picture uses Boolean to (0,1).  Your VI used Boolean Array to Number..
Message 14 of 47
(1,013 Views)
Griff22 , what is that? It is not working? Are you kidding me?
to the others I should say that it is with boolean to numebr or boolean to 0 or 1 , it is not working.
 hope there are some professional nights in here.
Message 15 of 47
(1,002 Views)
Okay if you are trying to find out the error between the 2 arrays, start with the arrays the same size.
Try this Vi Just change the numbers in the array and check the results. Answers are in percentage.
( by the way for someone who is asking for help you could be a little nicer.)
Have a nice day.
Message 16 of 47
(997 Views)
BER IS 0 for two examples in picture. BER must be less than 1.
Message 17 of 47
(989 Views)
Ok, sorry.
I can not open your design, My version of labview is lower. Could you please send me the picture? I want even when 2 arrays not in same size, is working in this way?
Message 18 of 47
(978 Views)
try this. It should take into account the diffeerent size arrays, and output a false for the ones that are "Extra" in either array. It also will divide by the larger of the 2 arrays.
Message 19 of 47
(969 Views)
I do not have Labview 2014. What is the name of your  two new blocks. I do not know their names.
Thank you
Message 20 of 47
(958 Views)
