04-16-2014 03:43 AM
I’d like to suggest a small change to the way the actor framework message maker works.
At present - regardless of the icon of the method for which the message class is being produced - the following VI icons are created:
Do.vi
Send <Method>.vi
<Method> Msg.ctl
How about if instead the message class takes its VI icons from the method (with the existing glyphs layered on top). So if the method icon is:
The following icons will be produced:
Do.vi
Send <Method>.vi
<Method> Msg.ctl
OK, its not gorgous and may need a bit of tweeking but I think this might make the Actor Framework quicker and more intuitive to use.
Dan
04-16-2014 05:38 AM
Might be useful to bring it to the attention of the Actor Framework enthusiasts: ni.com/actorframework
04-29-2014 05:48 PM
