01-08-2016 09:31 AM
In Labview 2015 should be a Actor Framework Message Maker Dialog Box.
I create a new project from the Actor Framwork Template, but can not find in the Tools menu Tools»Actor Framework Message Maker.
In the context menu of Task.vi in Alpha.lvclass I have Actor Framework»Create Message.
So I can create a new message class.
But why is Tools»Actor Framework Message Maker missing?
Solved! Go to Solution.
01-08-2016 10:23 AM
Interesting, can you post this in the AF Comunity Directly? It'll get much more focused attention there
https://decibel.ni.com/content/groups/actor-framework-2011
01-08-2016 10:53 AM - edited 01-08-2016 10:57 AM
The Message Maker was deprecated. The 'Actor Framework' right-click menus in the project window in LabVIEW 2015 and later should provide all the functionality previously provided by the message maker.
I thought we removed the help topic, I'm not sure why it's still showing up in the LabVIEW 2015 online help. I filed CAR 565761 to get the documentation updated.
01-08-2016 11:00 AM - edited 01-08-2016 11:03 AM
Thanks.I have also Labview 2014 installed with the menu Tools»Actor Framework Message Maker, but not with 'Actor Framework' right-click menus.
01-08-2016 12:07 PM
Right, to clarify:
03-03-2017 07:44 AM
To be precise: Right click the actor class of your interest in the project, go to "Actor Framework" and "Create Abstract Message for Caller" (LabVIEW 2016)
03-05-2018 09:51 AM
So, That gives me an Abstract Message. How do I create an ordinary non-abstract message?
03-05-2018 12:34 PM
There is also a 'Create Messages for Actor' right-click menu option that creates standard messages.
03-06-2018 02:35 AM
It appears that, first, you have to create a method for the message to link to. Only then will the Create message option be added alongside the Create Abstract message option.
Ian
