02-26-2010 03:02 PM
What Class/Method/Object's would I use to send variable form data to BradySoft? I have a basic label setup in BradySoft and I want to send it variable form data (a serial number) from Labview ActiveX. I have attached Brady's ActiveX programmers guide but can't figure out what to use for this.
P.S. I would call Brady or TekLynx tech support about this but they have a strict policy whereas BradySoft supports ActiveX but their tech support doesn't provide programming help with it. I figured I'd try the NI Forums.
Solved! Go to Solution.
03-01-2010 06:06 PM
Aaronb,
I presume by publishing an ActiveX programmers manual the BradySoft software installs Active X objects. You may choose to interact with these objects within LabVIEW using Active X controls. The following link will provide a starting point for LabVIEW help topics on Active X communication:
Select ActiveX Object Dialog Box
http://zone.ni.com/reference/en-XX/help/371361F-01/lvdialog/insert_active_x_object/
Building a Simple Web Browser Using ActiveX (Example of ActiveX arcitecture)
http://zone.ni.com/devzone/cda/epd/p/id/81
Hope this helps provide a bit of guidance.
Cheers!
Patrick Corcoran
Application Engineering Specialist | Control
03-02-2010 01:53 PM
03-04-2010 04:02 PM
Just an update. I was able to get this working on my own after a few days of messing with it (I guess the best way for learning!). I have attached a sample VI for anyone interested. Can we Kudo ourselves?
08-03-2015 06:20 AM
Hello-
I am using Labview ActiveX to call Codesoft for labeling printing requied.
I programed a VI as attached, but after run some days, a error appeared, and i tried your VI and got some error.
would you please help me? how to fix this error.
Many thanks-
Wei
08-05-2015 09:25 AM
Hey Wei,
This thread has been inactive for 5 years, I would reccomend posting a new topic thread in order to get more visibility on your issue.
Best,
Sam Kaley
Applications Engineering
