Hi all,
I use Keysight U4421A Protocol Exerciser to generate MIPI CSI-2 data with Keysight's Logic and Protocol Analyzer software. I works fine.
But i need to control this exerciser with LabView through ActiveX controls. I am connected to the instrument and i can control it, but i need to connect to Exerciser module and start him. I use TypeCast to convert generic Module reference into Ecerciser reference as it is in attachement.
If i want to start the Exerciser, the program does not work and it writes this error:
NI System Configuration: (Hex 0x80070057) Invalid parameter.
But StartExerciser method does not need any input arguments.
If i use any other method (GetXmlFormat, Execute Command,..) the program fails with no error.
Use i right the TypeCast Control?
Do you know any solution, how can i control the exerciser?
Thank you.
