I placed an ActiveX Control WebBrowser in my Application to display the remote panels of different VIs which run on a realtime system.
In the Development Environment everything works fine. But when I build an executable I first get a popup message which says that the webserver cannot be started. Just a second after I get a message of a fatal internal error ("LVClient.cpp", line 271...") and the application crashes.
I tried different settings in the application builder but nothing helps. Without the ActiveX control I don't have that problem. I use LV 8.20 and WinXP.
thanks for any help!
Dave
