07-17-2017 02:01 PM
Active X component is very slow to launch; in below image, the part that is circled takes about 7 seconds to execute.
After the Action Log becomes active, it works well. Just takes too long to launch. Any ideas?
Labview 2015 Pro, DSC Module, Windows Server 2012 OS
Solved! Go to Solution.
07-19-2017 08:05 AM
Hi !
Did you try in another developer machine? Same behavior?
Let me check.
07-21-2017 02:38 PM
At your suggestion, I tried it on another server. The VI launches immediately! Any clues as to why it comes up slowly on the this new server? It is so slow that the title bar changes to the familiar "(Not Responding)".
Gretchen
07-24-2017 08:44 AM
Main differences between both servers? Can you go to task manager and see what are both running?
07-24-2017 12:25 PM
Both look the same: servers are dedicated to this one Labview project
07-25-2017 02:31 PM
Just to be clear, are both servers that we are discussing on the same or different machines?
Are these both being run from the same user account (or at least as an administrator)?
Assuming the VIs are the same PC, are they running from the same drive?
Best
07-25-2017 03:23 PM
Hi, I appreciate your time in helping me out.
I have two distinct server machines! One is the existing server/Labview system, put into service in 2015.
The 2nd one is a brand new Windows Server 2012R2 which is the development server. I moved a copy of the Labview application from the existing to the new, and then started the Phase II part of the project. The VIs that use the ActiveX objects are the same as on the existing server/system currently in use. On the development system, the 'Action Logs' (the Active X objects) work once the VI completely launches. But it just takes so long to come up.
This week, I have tried:
07-26-2017 11:04 AM
realized I didn't answer all of your questions:
Yes, running from the same account on both servers, and yes I have admin rights.
All VIs are located on drive C
Gretchen
07-26-2017 11:47 AM
One more additional bit of info: I am using the add-on DSC Module, Alarms & Events display feature
07-26-2017 12:37 PM
I figured out what my problem was! I am working with a DSC Alarm & Display ActiveX Object, and there is a 'process' associated with it. When I right-clicked on the object and chose Alarm&EventDisplay -> ChoseProcess, it showed me that the process from the other server was still associated with the object. So, the delay in activation was due to the fact that it was connecting to the other server over the network.
