03-20-2012 02:27 AM
I've had LV 8.5.1 on an XP machine for many years then the power supply died. I now have a new Windows 7 PC and trying to reinstall LV8.5. I go through the activation process and it says "Product Successfully Activated!". License Manager says it is activated for this machine. I've tried multiple times. I've tried running as an administrator and as THE local admin but still says I have an Evaluation Licence with X days remaining each time I launch.
Any ideas?
Solved! Go to Solution.
03-20-2012 02:56 AM
could be worth giving NI customer service a call, they should be able to help. if you get a solution that way could post it as others may be interested.
thanks
03-21-2012 01:31 PM - edited 03-21-2012 01:31 PM
Hello WozFromOz,
If you could private message me with your serial number then I can make sure on my end if your new installation is correctly activated on our machines. Also, one of the reasons why "Evaluation License with X days remaining" could be popping up is that LabVIEW base/full is fully activated but application builder, an add-on for LabVIEW, is not activated. In many installations, they install together so you can try out application builder with your system. If you could post a screen shot of the evaluation screen that pops up alongside the NI License Manager with the files under LabVIEW 8.5 expanded, it would help me see if this is actually the case.
03-29-2012 01:52 AM
After a few days of kind assistance from Tamdemonium without success, I spoke to an NI Australia techo and he was able to diagnose and fix the problem quickly. It seems that sometimes LabVIEW does not pick up the right Computer ID to use for auto licencing so he generated a new one from my network interface's MAC. In future I have to activate manually after getting a code from them.
04-19-2017 08:31 PM
Hello every one, I called the NI support, they told me It wasn't compatible with W7, Which was the solution for you???
