Reply
Activation Code
Activation Code
Where can you view your activation code for LabVIEW.
I already have it installed, licenced, activated, etc.
I just wanted to find my activation code.
I thought if you were in LabVIEW and pressed
Help >> About LabVIEW
it would show you, but I cannot find it.
Cory K
(9,954 Views)
Re: Activation Code
Unfortunately, the NI License Manager does not display this information. When you activated the product did you ask for an email confirmation? I believe the code is provided in that email.
(9,938 Views)
Re: Activation Code
Yes, you can get the activation code only if you have requested for the confirmation mail during activation. If you didn't select the option and desperately need the activation code, right click on the product (in NI License Manager), deactivate the product and activate it again with requst for email confirmation enabled.
"A VI inside a Class is worth hundreds in the bush"
യവന്‍ പുലിയാണു കേട്ടാ!!!
(9,910 Views)
Re: Activation Code
Open the registry editor (start...run...regedit in Win XP) and look for:
HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\License Manager\Activation Codes
The key names are a little "short", but you should be able to figure out what they mean (e.g. LabVIEW_PDSM_PKG:8.0600 =LabVIEW professional 8.6)  Since LabVIEW has reigstry access tools, you could even write a small VI that lists them for you.
(9,897 Views)
Re: Activation Code
Here's is a very primitive VI (LabVIEW 8.0) that lists the activation codes from the above mentioned location. Smiley Happy
(note that you apparently also get the empty default key. You could suppress that with a little bit more code)
Message Edited by altenbach on 09-06-2008 09:38 AM
(9,892 Views)
Re: Activation Code
Thats cooool, Altenbach!!!
(9,888 Views)
Re: Activation Code
It would be quite trivial to make this into something that would be acessible from e.g. the tools menu in LabVIEW, similar to the code capture tool.
Still it's probably not worth cluttering the menus with something nobody ever uses. Smiley Wink
Of course I have no idea how to get the activation keys on a non-windows OS. Anyone?
Message Edited by altenbach on 09-06-2008 10:45 AM
(9,876 Views)
