07-14-2014 09:56 AM
Hi All,
I wrote an application that uses the Adobe ActiveX element to display a PDF.
This code used to work fine, but when I updated my acrobat reader from 11.0.06 to 11.0.07 it causes the application to start very briefly displaying the icon in the taskbar but then close (without an error or warning notification).
When downgrading to 10.0.06 the problem was solved.
Perhaps this can be of help for others who are experiencing problems with LabVIEW / Acrobat Reader.
Chris
07-14-2014 11:45 AM
07-14-2014 01:06 PM
07-15-2014 12:38 AM
07-15-2014 01:51 AM
Hi Chris.
We are well aware of the problem. We have documented it as CAR#480386.
You can also find the official response from Adobe in this link:
The AcroPDF.PDF Class is no longer accessible from VisualBasic6 after update 11.0.0.7.
So for now, I would advise you to use Adobe 11.0.06.
07-16-2014 09:37 AM
Sometimes I used this solution proposed by Jim (open PDF in browser) but I will prefer avoid browser because It is slower than activex and also methods from activex are missing.
Regards
Golzio
