Acquire Two Data at Different Rate Using Timed Loop
Hi, I'm acquiring Temperature Data and Analog Data using Real-Time. I want to acquire Temperature data at a frequency of 5 Hz (200 mS - Period), and the Analog data at a frequency of 500 Hz (2 mS). I have this case structure in order for me to select what data I will be displaying on my Host VI. Can you tell me of a way to set the setting for my timed loop to achieve this setup. Here is a screenshot of my code
(2,745 Views)
(2,736 Views)
Hi gijude,
simplest solution: use two loops: one for AI, another for temperatures!
I suspect it isn't a good the best idea to put network communication into timed loops used for better usage of determinism…
(2,697 Views)
