04-09-2014 10:11 AM
Hi guys,
I need a little help on this program i write. Its a dual channel program. I want to be able to read from 2 channels of mydaq.
I dont know why it can't show we the waveform, and can't keep running.
Thanks!
Solved! Go to Solution.
04-09-2014 10:14 AM
Please check out the provided DAQmx examples in the Example Finder (in help-menu).
thanks,
Norbert
04-09-2014 10:25 AM
More specifically, look for Voltage - Continuous Input.vi. It isn't that much of a leap from there to add another channel.
04-09-2014 10:42 AM
Thanks to both of you!
I think it works basically. I use a case structure, so i can choose which channel to check each time. Can I get 2 waveforms at the same time? Or I can't because I'm using the same mydaq device?
Besides, how can I record two channels data together?
Thanks again!
04-11-2014 02:19 AM
There are also examples available....
For multiple channels, you simply have to state both in the channel input.
Norbert
