Accessing every other data point in a dynamic data type (question in attached images)
So I thought that my question would be best explained through word equation editor, so I have attached screenshots explaining my situation and what I am trying to do (temp 2).
Message 1 of 9
(2,768 Views)
Yes, many quite more efficient means.  For example:
"Should be" isn't "Is" -Jay
Message 2 of 9
(2,750 Views)
Thanks a lot! I'll try this out
Message 3 of 9
(2,741 Views)
You'll notice that Jeff's suggestion does not use the Dreadful Dynamic Data Wires.  You would be well-advised to similarly learn to not use these awkward hard-to-use data structures.
Message 4 of 9
(2,726 Views)
Divide by 2 and round down could be replaced by the quotient from Quotient and Remainder,
For Array Subset, should that wire have gone into Length rather than Index?
Message 5 of 9
(2,706 Views)
I'd like nothing more than for the DAQ assistant to just output the DAQ card info in an array. Is there an option to configure it this way?
Message 6 of 9
(2,663 Views)
Express palette >> Signal Manipulation has another Express VI called From DDT.  That converts blue wires to other data types.  You configure the express VI to output the type of data you want.
Message 7 of 9
(2,661 Views)
Thank you!
Message 8 of 9
(2,657 Views)
Yes,  Right Click the Express vi after you have the task configured and select "Generate Code>>Configuration and example" Grab a cup of coffee then save the vi
Message 9 of 9
(2,652 Views)
