09-16-2014 08:52 AM
I had this error when i tried to run application (EXE) file create from vi.
Access violation (0xC0000005) at EIP=0x3052D62C
Version: 1.0.0.0
I have already repaired LabView but still the same error appear, any help?
Thank you in advance,
Thanya
09-17-2014 01:39 PM
Are you using a Call By Library Function Node?
When do you get this error? Is it as soon as you launch the exe? Did you send an error report when the error occurred?
Would you be able to post your code so it can be examined for further troubleshooting steps?
09-17-2014 02:02 PM
Hi Thanya,
To isolate the specific code causing the error, it can be useful to add user-dialogs before and after operations.
By the way, does your code require any special DLLs?
Cheers!
