Access filter node using scripting
Hi All,
I'm having a look into scripting and have run into a problem. I'm placing an event structure and then creating the Panel Close? event with a True constant inside. This all works fine. I then want to wire a true constant to the output filter node Discard?.
I can do everything other than find the reference for the node. The input nodes are numbered using the Node.Terminal property but I can't seem to get to the output node?
Any help would be greatly appreciated.
Greg
(2,952 Views)
Accepted by topic author GregPayne
I've figured this out.
If anyone is interested, there is a method of the Event Structure reference that returns the filter node reference for a specific frame.
(2,912 Views)
