Access a queue inside a built labview application .exe
I have a built labview application .exe within which there is a queue. I would like to put items into this queue from a labview vi which exists outside of the application.
Is this possible?
thanks you,
labJunky
(2,953 Views)
Accepted by topic author labJunky
With the correct modifications, sure. You can e.g. setup a TCP listener in the .exe and send commands that way.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(2,928 Views)
Thanks for your tip! I was just researching "network streams". Which is easier to implement?
(2,924 Views)
I haven't really tried network streams, but as they are a newer addition it's supposedly a little easier to get started. 🙂
/Y
Qestit Systems
(2,917 Views)
I think I will try UDP messeging. Thanks Yamaeda!
(2,897 Views)
