03-28-2008 11:00 AM
03-28-2008 11:01 AM
03-31-2008 04:43 AM
03-31-2008 04:41 PM
Hi Capri,
Vision Builder for Automated Inspection (VBAI) is designed to work with any NI frame grabber, GigE Vision or IEEE 1394 cameras, or the NI Compact Vision System. Since this the AXIS PTZ 213 is a network camera VBAI is not designed to interact with the camera directly.
An option is to pull an image into VBAI from LabVIEW using the "Run LabVIEW VI" step and run the inspection from there. Once you are able to acquire an image from this camera in LabVIEW follow these steps to bring the image into VBAI:
Create a VI that has an IMAQ display as a control and an indicator. The control is to create an input for VBAI to communicate and the indicator is the output of the image. Next, open VBAI and add the step for Simulate Acquisition. Then run this step by itself – this will create an error, ignore it and click ok. This step creates an image buffer for your AXIS image to fill. Next, include the Run LabVIEW VI step and choose the VI you created. In the setup pane on the right, select the VI Controls tab. Click the Configure button. Choose the IMAQ display control you created and select Use Measurement. Finally, select the Simulate Acquisition step from the list. From here on you should be able to pull images from LabVIEW into VBAI.
Does this help?03-31-2008 06:18 PM
04-01-2008 09:19 AM
If there is something I did not explain well in my last post I would be happy to clarify.
04-06-2008 05:12 PM
04-07-2008 04:19 PM
04-07-2008 05:04 PM
04-08-2008 07:03 AM
