05-08-2003 02:35 AM
05-08-2003 08:08 AM
05-08-2003 10:06 AM
03-15-2005 11:29 PM
03-16-2005 11:50 AM
03-16-2005 09:19 PM
03-17-2005 08:50 AM
04-07-2005 05:37 PM
05-17-2012 09:29 AM
You've probably solved this problem long ago, but I came across this thread a couple weeks ago when trying to do the same and thought I post this .vi for future users. This code is for a multitech MT5656ZDXV modem, but I think the AT commands are generic enough to be used with any voice modem. Hardware configuration requires and audio cable running from the PC speaker to the modem mic port. Also, I had to use a Konnex Office Konnector telephone line A/D which required me to manually pick up a handset; the software prompts the user to do this. Fancier A/Ds should eliminate the need for this and I have one on order. If you have an analog phone line then there should be no need to use an A/D or manually pick up the phone.
