NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
DannyBoyD
AP2722(instrument driver) or AP2222(ActiveX to APWIN)
I recently asked a similar question but I want to try to re-ask a better question.
Is it well known that using Instrument Driver with 2722 will have easier implementation than LabVIEW with AP2222 via Active X?
I have the option to use either but I was just curious if the collective experience had an opinion about which one might be better to use.
thanks
Member
Che_T.
Re: AP2722(instrument driver) or AP2222(ActiveX to APWIN)
Hi Danny,
You would be better off using the instrument drivers.  The 2722G and 2722A are NI certified, meaning that we've tested and verified it.  However, the 2722 is not NI certified, and may have bugs.  The instrument drivers can be found here:
http://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/catnav:id,ssnav:sup/q/2722/
The advantage of using the instrument drivers is that you have access to the code and functions.  If you do detect an error, you can troubleshoot it.  With ActiveX, you'll have to trust the publisher of the control that all of the functions work correctly.
Che T.
Member
DannyBoyD
Thank you.
Member
enes
Hi
I am using ap2722 for my graduate project. I have to generate offset voltage from ap 2722 output. how can i generate offset voltage by using ap 2722's labview driver
Member
Allison_M
Hi enes,
Which driver are you using to communicate to your device? Is it the 2722G, 2722A or 2722?
Allison M.
ni.com/support
Member
enes
i am using 2722 for project, driver name is "Audio Precision 2700 Series".
thanks,
Enes Karav,
Student of Electronics Engineering
Istanbul Technical University
Member
Allison_M
Hi Enes,
As Che T. mentioned, the 2722 driver is not NI certified. I would recommend contacting the company who makes your device or else hopefully someone else on the forum will have used this device driver successfully to set offset voltage.
Allison M.
ni.com/support
Member
enes
Thank you;
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
